Running subs in parallel?
  • 3
Originally posted by Justinh722 If i were to wire my subs in parallel from 4 ohm to 2, and if my amp was 2 ohm stable, would running my subs in parallel make them hit harder?
if you play with the wires, that's raising the output of your subs...
i don't think anysort of wiring would raise the handling capacity of a speaker... your AMPS would hit harder, I should think....
Ok, be easy on me, this is all just my 2 cents....//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As I understand it.. your amp puts out more power at 2 ohm than at 4 (in general, not all amps do this).. but it has to be 2 ohm stable or it will shutdown or melt.. since you get more power from 2 ohm, your subs will be getting more power (and hitting harder, unless they blow)..
The amp will run hotter as well.. just so you know..
so i have a rockford 250.2 and it says its 62.5 watts at 4 ohms 125 watts at 2 ohms does this mean its 2 ohm stable if it says how much power it is running at 2 ohms?
Originally posted by Justinh722 so i have a rockford 250.2 and it says its 62.5 watts at 4 ohms 125 watts at 2 ohms does this mean its 2 ohm stable if it says how much power it is running at 2 ohms?
yes, it is 2 ohm (stereo) stable...
if you ran 2 channels (i.e. two speakers linked to the left and right terminals), that'd be 125watts to EACH channel...
hmm, if it was 2 ohm mono stable, then you'd have about 250watts in one channel...
tell you what, why not got o RF's webiste, go to RFtech and library archive...
get your user's manual... it's stated specifically what yor amps can handle...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's how I found ALL my RF product manuals again~
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
741
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Justinh722
Justinh722
Mason City, Iowa
paikiah
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
