DJ Riggz
don't ride no white horse
Ok here's what i've got:
1 12" Eclipse 88120DVC 500w rms 1000w peak (2x4ohm)
1 Memphis MC1000D 600w rms (2ohm)
I've searched around for info on this for over a week. I want about a 50/50 split with SQ/SPL. Eclipse recommends i put the sub in a small sealed enclosure in the range of 0.5ft³ to 1.0ft³. I want to hit the lows and have some hard thump. I'd also like pretty tight bass. So my questions are: Should i stick to sealed or try a finely tuned ported/vented? Will it not do well in anything other then a seald box? Thanks in advance!
Specs:
88120DVC
DC-R: 3.1ohm/coil
Fs: 27hz
Qts: 0.30
Vas: 3.20ft³
SPL: 89.4 dB
Qes: 0.322
Qms: 5.0
Sd: 0.0511M²
Xmax: 1.30"
Displacement: 0.10ft³
Specs:
88120DVC
DC-R: 3.1ohm/coil
Fs: 27hz
Qts: 0.30
Vas: 3.20ft³
SPL: 89.4 dB
Qes: 0.322
Qms: 5.0
Sd: 0.0511M²
Xmax: 1.30"
