should i buy these amps
bigrob_81
11
az
are these amps worth buying or should i keep what i have
i have a
6 channel older ppi p650 amp
want to run the mids highs off
and a older
white crossfire amp 300x2 whatever that means
to run my (2) jl audio 10" w3's
or should i buy my buddies
Pioneer 200-Watt x 2 Bridgeable MOSFET Amplifier with Tri-Mode Power Distribution Model: GM-374 to run my jl audios
and buy the
Pioneer 240-Watt Bridgeable MOSFET Amplifier with Tri-Mode 3-Way Power Distribution Model: GM-X372
to run my mids highs
he wants like 80 bucks for them should i buy them or keep what i have already could they be useful or not please help
Yea, thats a great deal. Buy them both and hook them up to see which one you like better. A 6 channel to run mids and highs seems a litte much. you could bridge channels 1-4 to create 2x150 for a comp set and 50x2 in the back for rear fill if you think that is neccessary.
In regards to the PPI 650.
If you bridge channels 1-4 for your comps, you will be getting 200 x 2 for each speaker. I don't know if there are any comp sets that can withstand that much wrms. And the last 2 channels on that amp are sub dedicated, they have a built in 90hz low pass filter.
That amp is meant for chan1-2: front speakers, chan3-4: rear speakers, chan 5-6:subwoofer.
It's an awesome amp and has better specs than most other amps out there. I am getting mine repaired and will run my sub off the sub channels bridged and use the front speaker outputs, have not figured what to do with chan3-4 since i will have no rear speakers. Maybe I will add a midbass set somewhere in my car.
The Pioneer cannot touch it with a 10-ft pool, this amp makes things sound the way they are meant to sound.
Have you check to see if the prefab would fit...
13
There will definitely be a mechanical noise when you overpower the speakers. That sound will show up long before overheating the coils. Like most...
Aw.... You're talking about good ol' Mich.
15
741
The CT's are nice, That Sundown is a a frik'n beast!
7
bigrob_81
bigrob_81
az
Breogan24
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
