Is the JL ported? How many watts does the 6.5 handle. Either way, I would take the JL. unless you're pushing a tremendous amount of power through those 6.5's, that JL will be louder.I have 2 6.5 savards high q in a small ported box under rear sit should I trade for a single JL 10tw3 ? Will it be louder or no thanks in advance.
That's a tough one. I am pro JL but those Savards look impressive. 2" voice coil while the JL is 1.5".I have 2 6.5 savards high q in a small ported box under rear sit should I trade for a single JL 10tw3 ? Will it be louder or no thanks in advance.
I've worked with some great 6.5s a local to me guy is selling, RDS Audio. They can be surprising output wise. As always it's really all about the enclosure even with quality drivers.I'd also like to see pics. Thinking of putting 4 6.5s under the back seat of my truck. Based on specs alone, I'd guess it wouldn't be much different. The jl has a little more surface area and xmax, but you can put almost double the power to the 6.5s. But I haven't heard either, so couldn't tell you.
After seeing the specs on those Savards, I would definitely go with the W3. It pushes more air, handles more power, and can hit deeper notes.I will put some pics of what I got now when I get home later today.
With 2 of the 6.5s they will handle 300 watts more than the single jl.After seeing the specs on those Savards, I would definitely go with the W3. It pushes more air, handles more power, and can hit deeper notes.
I read the power ratings wrong. The Savards are 300 watts each, and the JL is 400 watts. However, the JL has more surface area and the parameters are better all around. It would be an interesting comparison. The JL will definitely sound better and lower frequencies, but...With 2 of the 6.5s they will handle 300 watts more than the single jl.
The guy who got his posts deletedAre you referring to me?
