speaker wiring???
  • 3
Its harder to have load options for door speakers seeing as they are all single voicecoil. If it was me I'd just buy a 4ch amp and be done with it. Unless you are trying to run 2 sets of components, and are trying to power 2 tweeters and midbass. In that case I'd buy a 2ch amp, run the midbass on the 2ch amp, then run the tweeters off the headunit.
do not run the tweeter off the head unit, run the crossover off of the amp u choose becasue it will do its job and crossover the freq for the comp system. dont seperate a system thats ment to be run together.
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
858
Parallel at the amp is the same as parallel at the speaker then to the amp. Just like parallel off of a single subwoofer driver with two voice...
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
5
Lower impedance does not burn up speakers...too much power or a distorted signal are what smokes a coil...
12
snakey5138999
snakey5138999
Schenectady, NY
FenixAudio
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
