Speakers Hummm when Sub hooked up.
  • 3
vette1
ohio
I have a Pioneer VSX-D608 and just purchased a Monster HT SL100-SW THX Subwoofer. When I plug the RCA cable from the Sub out on the Reciever into the subwoofer all of my speakers start humming. Anyone have a clue what the problem is?
Thanks
Get a 3 to 2-prong adapter, and plug the sub into it.
If the hum disappears, you've got a ground loop.
Is everything plugged into the same outlet or power strip?
Wow, I never thought of that. I used a 3 to 2 power adapter and now it works..... **** you just saved me alot of time... What is the cause in my wiring in the house that would cause this?
Shawn
You have read the whine-and-ground-loop sticky here, right? I've only had alternator whine in one install, and it was nearly impossible to...
12
473
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
606
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
377
vette1
vette1
ohio
vette1
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
