Spliting a port.. and putting one on each side.
Bill T.
Wyoming
On my XXX box, I had a 4" X 14.5" port with a length of 26".
Would tuning change (or any other factor) if I put 2 - 2" x 14.5 ports on both sides of the box with a length of 13"? The next box Im planning, I want everything to look square. So would that be correct?
Bill T.
Btw, it will be for 4 SE10s. Box after port displacement (assuming the ports above are correct) will be 5.15 cu/ft with a hopeful tuning of 33Hz.
Use to be a popular setup in the s10 trucks used in competition....most were well over 150dbs ....
4
589
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
Bill T.
Bill T.
Wyoming
helotaxi
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
