Stereo rapidly changes through presets on its own
Nonsense301
Texas
I put my pioneer avhp1400dvd into my new truck from my mustang.. didn't previously have any issues.
Installation went smooth and started up fine, however when in Radio source it will rapidly scan (to the left) through all of the presets as if the left button was being depressed very fast (holding will scan through individual channels)
Hitting the home button for the menu to pop up doesn't work either, the home menu will display only for as long as I'm holding it.
When using CD as a source, it doesn't have any of these issues except for the home button not working... could there be some wiring fault causing this?
That being the case, check out eBay. There are similar models on there with the same trim piece.
195
Do you know how much mounting depth you have? Is it a crew cab?
4
538
If you are not into the super loud sound with rattling bass then a quality headunit and speakers will suffice. Make sure the equipment is from a...
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
Nonsense301
Nonsense301
Texas
Nonsense301
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
