Sub Box and Trunk Spacing
Aaron407
Canada
hey everybody
someone's gotta know this. I have a sealed, dual sub setup with them firing backwards. I plan on making a new box, and I was just wondering, how tight should the box fit in the trunk? I had heard that there should be a decent sized gap to stop spl buildup in the trunk and to allow the pressure to more freely enter the cabin area. With my setup, I'll only be hitting at most mid-130's, so there won't be any extreme pressure, but with about 3 to 4 inches on each side of my current box my trunk already rattles pretty badly. Any suggestions on how much of a gap should be left?
407
My problem doesn't really regard whether or not it's ported, it's still going to build pressure in the trunk. And spl gain isn't really my concern, at this time I'm really only concerned with fully channelling the existing spl from the trunk area into the cabin area (keeping it as equalized as possible). Does anyone know what size of gap would be needed for this channelling?
407
Maybe I'll try explaining this a little better. I'm going to be making a new box for my two subs. I won't have any significant gap between the top of the box and the bottom of my back dash. Should I have the box's width made so that it fits tight between the wheel wells, or should I leave a certain sized gap to allow sound pressure to flow around the sides of the box? Or will this gap really make any difference? Any recommendations?
407
Is there no way u can make the height of the box smaller so there is more of a game between the back dash the subs? Would have thaught thats where the most difference will be made.
If not ur right logicaly leaving a sizable gap at each side will allow room to releive air presure, if its in a realy small enclosed space it will build up much quicker.
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
Have you checked out these shallow drivers from DD? A friend had 4 of them and man, it took it to the house for what they are...
6
567
  • Locked
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
3K
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Aaron407
Aaron407
Canada
Sharp_Shoota
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
