sub wiring please help
karson3773
i have a jbl 1200.1 amp and 2 10" audiobahn aw1006T's at 900rms each. there are 8 connections on each sub, one one side there is 2 pos and 2 neg and the same on the other side.
how in the hell do i hook this up in a 1ohm load or 2 if possible?
i tried the voice coil diagram but when i turn up the volume, the system shorts out please help me
wait you mean each sub has 2 voice coils(dvc), right? Are they dual 4 ohm or dual 2 ohm? If there dual 4ohm, wire the coils together in paralell to achive a 1 ohm load. Still, it should not be shorting out no matter how you wire the speakers. When it comes to amps, you get what you pay for.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
649
A little DAP will do ya, drill, feed & seal, done.
931
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
karson3773
karson3773
omaha,ne
Crapstain
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
