Subs and boxes
My bad, I meant to say "Subs"
It had been corrected. //content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
This is what I want to do either:
two 8"
two 10"
one 12"
or one 15"
I need my trunk space, so if the bigger the sub, the deeper the sound, I'll just get one "larger" sub
Thanks
What kind of box would be better for a deeper sound?
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
381
Aw.... You're talking about good ol' Mich.
15
743
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
476
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
H1PH0P
H1PH0P
SF
H1PH0P
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
