subs for rap music
skatenc
nc
i was planning on geting a 15" magnum d2 but i have seen this sub discribed many times as being "punchy". this sounds like this sub is meant more for like rock music and fast quick bass lines not deep rap bass. correct me if i am wrong i am just a litle bit confused. wouldnt the 15 be a little deeper? would this sub be fine for rap or does anyone have recomendations for a sub a little better suited for rap than rock thanks
When most peopel say punchy abotu the magnum they mean its veryaccurate from what i hear it hits lows with the best of them.
I think a mag will work great for what you want.
As for a suggestion for something that would work even better for rap.... check my sig.
so would a XXX fit my Rock and Roll style better with that technology than say a Mag?? I listen to alot of live music: i.e. Phish, Widespread Panic, MOE., Gov't Mule, Moonshine Still, etc. suprisingly alot of people that listen to these bands don't spend much money on systems. I try to get my system sounding as close to a live show as possible.
Magnum d2 will not disappoint you at all. I have 2 12" in 2.5 cubes each ported @33hz. With near 1400 watts rms on each one...the experience is just amazing. It was even amazing when i first had 700 watts total. BUT, anyway...i listen to all types of music. It is accurate and well rounded on all my rock and with the rap...WOW it is loud and amazing. It's accurate even with rap, and my box does go boom...lol. peace
NG
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
skatenc
skatenc
nc
ngsm13
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
