Subwoofer suddenly jumps levels? Help please!
thefreeman1212
Canada
Firstly I want to say I am a noob at wiring, but trying to learn.
I bought the car used, with the stereo and all already installed. They also tried to install LEDs, but the wiring was so terribly done that it was creating interference with the console (not very important, but I am guessing it can be a wiring issue with how it was before.)
So the problem is: I have the subwoofer level set to 0 on the console. The sub is not loud, which is should not be. Then randomly, the sub gets very loud, similar to when it is on max. I do not touch the console or anything. Sometimes it will drop back to normal after several minutes, sometimes it stays there and I have to bring the level to -9 to get it the same as it was at 0.
I have no idea what it could be!
This is my setup:
10"(12"?) kicker subwoofer (1200w i believe)
JL Audio JX360/4 Amp
JL G-Max 1200w Class D Sub Amp
JVC KW-AVX640 Console
Music from iPod via USB
Any help would be appreciated, as I do not really know what I am doing! Thanks!
Your ground is bad on the amp or the amp is on its way out close to death //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif...
try testing with a cd. sometimes different music on the ipod will give you different output volumes depending on the quality of the recording.
Yeah was thinking of those, they cost arond 130€ here from the store, so my best bet is to buy locally if i go with them 😁
5
264
Plus one. Works in as small of a box as .7 cubic feet sealed. Also had mine in a 1.75 cubic foot box ported to 36. ****** slammed. Only thing was...
5
248
I'd predict a shallow roll-off below tuning with the smallish airspace. Yes. Modeling only shows +5db around tuning. Would anyone like a...
435
I used an Sa-12 classic for modeling. (.14ft3 displacement) Mounting cutout: 11 1/8" Depth available: over 12" (plenty) Actual tuning is 34.75hz...
thefreeman1212
thefreeman1212
Canada
CrossoverOre
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
