Sundownz please help!!!
  • 6
dancindan85
WI
ok I ordered 2 SA-15's d4s from woofer-etc just recieved them today and one of them makes a horrible sound. it sounds like the voice coil is rubbing on the wall of the motor or the post. almost like the cone isn't inline right. i contacted woofers-etc just now but wondering what your take is on it or if anyone else knows what it is or if it can be fixed and not shipped back...?
99% likely it's not a factory defect as we still test all the subs that go to WoofersEtc just like we test them that go everywhere else -- it may have been knocked around enough to shift the motor. In any event -- we can check it out and replace it if necessary.
PS: E-mailing us is alot better way to ask this type of question.
i would also check out the dust cap could have came loose a lil and that makes alot of noise.
if the top plate has shifted you will see it is off set, take a peek..
played them a lil bit more and the one sounds fine now. idk wtf the deal is. whatever thanks everyone for the input.
so I took out the one that was making noise and it looked like something was stuck between the coil and the motor. slight scratch on the coil...
What he said.
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
807
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
734
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
dancindan85
dancindan85
WI
SPLaudio
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
