I have made the switch from Eclipse aluminums to a single rockford power hx2 12 after two of the Eclipse cone's ripped and one of my friends ripped (yes, the aluminum actually ripped). Since they don't cover this under warranty I'm pissed and switched back to the old reliable Power HX2 12" I've had sitting around. I'm just tired of the small .85 cuft sealed box that it is in and want to go to a ported box or atleast a harder hitting sealed box. Does anyone have any recommendations? I had to reformat my hard drive and I lost the "bass-box" program I used to have and an only find SUB13D online, which has given me differing results in the past at times. The specs I found online for the sub are as follows:
RFR3122
Dual 2 ohm coils
FS 26 hz
QTS .338
VAS 1.46 cuft
Xmax .74 in
SPL 85
RMS 1000 watts
Max 2000 watts
I used to have this sub in a system with a slotted box just over 2cuft that sounded great, but traded the box off to someone //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I will also be powering the sub with a Hifonics (yea yea) Brutus 1500 mono amp @1 ohm that I've been using for my home audio system. After those two eclipses going I'm not about to spend any more money for a little while..
Thanks everyone!!
RFR3122
Dual 2 ohm coils
FS 26 hz
QTS .338
VAS 1.46 cuft
Xmax .74 in
SPL 85
RMS 1000 watts
Max 2000 watts
Thanks everyone!!
