T3 TSS 10" enclosure help
  • 3
If you go small, you definitely want to stick with aeros. There shouldn't be much difference in sound between a properly slot ported enclosure and aero ported enclosure though.
If you need a design, send me a PM.
I am wondering if someone who knows anything about the T3 subs thinks a single 4" aero would be enough port area for these little beasts. I just think aeros have a cleaner sound personally, but I agree a properly designed slot port is great as well.
Seems to work great. Thanks! Here a transcript. Me: I need plans for a single vented 10" enclosure that is tuned to 32hz. One Sundown Audio E10...
7
785
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
960
jnralp00
well then...
jnralp00
Atlanta, GA
jnralp00
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
