bassheavy13
Premium Member
Premium Member
I'm starting this thread to educate people on the quality of this particular Taramp's amp. So far I have it installed and running off of 4 Deka group31 batteries in the trunk being charged by a 240 amp Mechman along with a 70ah agm starting battery. Right now I have 3 positive runs of CCA zero gauge and 2 negative cca runs to the back. Soon I will be adding 1 more battery, 1 more positive run of cca, and a 320 amp DC alt. I had a Flatline 7K with the same setup previous to this amp being installed. Too hard to tell any diiference other than my voltage is actually better. The system isn't quieter but not sure if or how much louder it is. The Flatline was flattened shortly after being installed so no numbers(wasn't the amps fault, user error). This is pushing 4 ZV4 12's at 1ohm which is what this amp is rated for. I don't know how often this will be updated but I will try my best(I work a lot of hours). Right now you can see this video I made before installing
