The benefit of # of subs 4,3,2?
LeX
Nissan by Nature
2,211
Atlanta, GA
Right now i have an elemental designs e12o, i am thinking of doing a multiple Image DYnamics IDQ setup because i really like their subs.
What would be the difference running 2 IDQs as compared to running more, as in 3 or 4 subs?
Is it worth the difference having more subs (if i can get them cheap)
also is there any way to run 3 DVC 4ohm subs at less than 2.6667ohms, or 4 of them at less than 2ohms (i know i can do them in 2 pairs, but how else? and with the 3?
Thanks //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
-Alex
Upsides to More Subs:
More cone area
Better Appearance (some people's point of view)
Downsides:
more power needed
more expensive
takes up more room
usually have to go sealed unless you have a SUV or van
more difficult to make a nice even install
as you can probably see, im more biased towards fewer subs and larger ported enclosures
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
LeX
Nissan by Nature
LeX
Atlanta, GA
Bumpin03
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
