Time to upgrade.....have question
  • 2
gmcguy
I've got a 2007 gmc sierra (new body) with bose system, factory nav, onstar,xm, rear seat controls, factory sub and amp. I'm getting ready to replace everything except for the head unit. For front and rear speakers, ive got jl audio zr650-csi and c2-650x. the factory sub is being replaced with 2 jl audio 10w1v2, and the amp is being replaced with a jl audio xd600/6. Im using an alpine pxe h650 integration processor. In order for everything to work like it did from the factory (onstar, steering wheel controls, warning chimes, etc), do i need to use any special interfaces? Also are there any wiring harnesses i can purchase to keep from butchering the factory wiring too bad? Things sure have changed alot!! Thanks for any help!
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
727
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
861
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
3K
Are you planning on upgrading the alternator and add extra batteries?
899
gmcguy
gmcguy
indianapolis IN
Phoenix Risen
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
