trying to decide on an alternator?
iceteebone
Banned
39,411
Michigan
i was looking to buy a 200 amp alt from one of the following companies: mean-green, dominick irragi or excessiveamperage. all of there alts. are 200 amps and 100 amps at an idle. excessiveamperage is the cheapest the next closet is dom's which is $50 more and mean-green which is $35 more than dom's. excessiveamperage has a 90 day warranty dom has a 1 year warranty and mean-green has a 2 year warranty. so i'm trying to decide which one to go with. any suggestions from people who have used any of these?
Personally, i'd go for the 1 year warantee. If it works for a year, chances are it has been built properly and will last you a while longer. Also, if your mean grean breaks after 91 days, you'll be kicking yourself.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
Just need to find id to get a users Manuel thanks
iceteebone
Banned
iceteebone
Michigan
iceteebone
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
