nickkramirez
agg
ok
I have a single 12" 2 ohm 2006 model Kicker L7.
i'm running it with the Hifonics Bx1205d mono amp.
the sub is 2 ohms, and the wattage the amp puts out to a 2 ohm sub is 900 watts.
I understand that, if the sub was 1 ohm, the amp would put 1200 watts to the sub, and if it was a 4 ohm sub, it would get 450 watts from the amp.
ok
so I want to buy another L7 and i'll need a new amp to run 900 - 1000 watts to each sub.
I don't know what kind of amp to look for, or how to understand the ohms.
both subs will be 2 ohms, and from what i heard, if I were to just use the amp i have now, it wouldn't put another 900 watts to the other sub, but it would just split the original 900 watts between each sub, and give each sub 450 watts.
so what kind of amp would i look for to run that power (1000 watts) to each sub?
and how would the ohms come into configuration?
would there be a total of 4 ohms when it comes to the subs, so the amp would put out whatever it says it puts out to 4 ohms subs?
if anyone understands what i'm saying, please this is what i need help on. or if you know of an amp that i can use and explain to me why it's the amp i'm looking for, then i would be greatly appreciated, thanks!
ok
