visonik subs
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
ShizzA1
ShizzA1
pdx
ShizzA1
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
