w6v2 sealed or ported??
i had mine in a sealed box
then i had 2 and put it in a ported box.
if you're more for sq put it in a sealed box.... people say they can "make" a ported box sound like its sealed.... i laugh at them and tell them to stfu..
since you have a 4runner, hummmmmmmm hard choice, i would say ported if you had a sedan and sealed if you had a hatchback........ HUMMMMMMMMMM ...
GO SEALED, you'll like the cleaness of it.. just get a nice looking box too, DO IT UP!
you can make a ported sub sound as good as sealed but you cannot take any sub and make it sound that way. usually low Qts, Qes, woofers can work well with ported enclosures and sound "tight" especially a sub with a little higher fs, like above 30hz. They generally have a higher f3 like in the mid-high 30hz region so it sounds more "tight". But low fs, high Q drivers put into ported enclosures usually exadurate low end and sound bloated and sloppier. W6v2 is one of these woofers, at least according to JL's specs, so I'd go sealed for best SQ with this sub, but generally I'm not satisfied with a single 12" sealed so personally I'd put it into a ported enclosure, and find another sub suited better for porting to get great sql ported.
If you want a super high quality "tight" SQ ported setup get a sub with low Qes/qts like less than .35
IDQ's are a great example of how "tight" subs can sound in ported enclosures, so are ID SPL series subs.
If I notice any resonance I'll just go ahead and throw some CLD to help out. Interesting thing I noticed though; when you go to buy the HT-18s...
15
695
I feel like that is more of a result of the cabin gain of your car and box size rather than tuning frequency. If the box is massive there will be...
12
570
Have you checked out these shallow drivers from DD? A friend had 4 of them and man, it took it to the house for what they are...
6
567
The 8" sealed will not sound anything like a ported box. Even a 6" in a ported will hit harder than an 8" in a sealed. However, the bass, from...
10
872
popothemailman
popothemailman
Oakland, Ca
limitkid7
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
