was it a bad selection?
boomnbreeze
21
Iowa
what type of enclosure should this be in? According to massive they say it "work very good in either enclosure. Please help and if anybody knows wherre i can get a good 1000w 1ohm rms amp please holla. Or anything bigga.
Huh, Ok I only understood about half of your post.
i cannot seem to find what type of enlcosure that this beast would work best in.....when i called massive tech. they gave me a run around and did not not know what in the blue blazes they were talking about, I was so so so mad i hung up. Called back the next day same thing....ahhhhh the insanity......can not find any info on sub......rms......sensitvity.....that sort of stuff..
well um i dont know what you askin exactly except for the amp part. you can try a hifonics brutus 1000d or 1500d which run at 1ohm, a jbl 1200.1 which is 1 ohm stable or a pg tantrum 1200.1 which i believe runs eiteher 1200 or 1400 at 1 ohm.
Massive Audio DMX-18 that is the model that it is...it is the biggest in the Massive DMX line. all i have on it is the "box building parameters" according to Massive.
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
X2 on the front amp. If you just want to use the BT, then you do not need to use the radio. In my home stereo, I have a rechargable BT dongle for...
78
boomnbreeze
boomnbreeze
Iowa
cjj2d
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
