Weird DVC Wiring Question
WarDrumz
Hebrew Israelite
If a person has a DVC subwoofer, and they want to run the coils in parallel, but the enclosure only has one terminal could they do this?:
Run a wire from one negative to the other, run a wire from one positive to the other, and run the wires to the terminal from the postive and negative that the have the other wires connected to them.
Would that work?
I was just thinking about that, and I'd just like some comments about it. Thanx
goto http://www.respl.com and look under wiring it will show you the wiring diagram for series and parallel wiring and the ohm loads they will drop the subs at depending on the humber of subs and wether they are dual 2's or dual 4's. That one terminal per sub should be just fine unless its a dual sub box with one terminal which if its a prebuilt box that shouldnt be and is soemoen built it they just werent thinking lol.
I recommend getting another box. Or not even buying a Wal-Mart amplifier. Stick to the brand names life Rockford Fosgate or Alpine. Then follow...
371
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
WarDrumz
Hebrew Israelite
WarDrumz
BABYLON THE GREAT
WarDrumz
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
