Went Shopping Today :)
PILOT 04
OHIO
Well, I finally got out there to buy the equipment for the Honda Pilot. Here is what I bought:
Alpine CDA-9847 Headunit
Alpine MRP-M350 Amp for sub
Alpine MRP-F240 Amp for mids
MTX T5510 sub
MTX Bass Slammer type box
Polk Audio DB650 speakers (two pairs)
I just wanted to add some omf to the Pilot since the stock setup *****. I stayed with Alpine because I got some great deals on the equipment that I couldn't walk away from (same thing with the MTX and Polk). Should be a nice change that isn't too overpowering that everybody turns there heads when I drive by. I just wanted a setup to help me enjoy the music a bit more. I am sure down the road there will be changes, but for now this is what I'm installing. I will post pictures of the install.......
WEll if you got the deals then your in good shape... it's easy to beat stock setups... enjoy, it'll be a nice change.. ohh 1 thing... wire you pilot with 0/1ga to start with.... don't cheap out and get less or you will just end up replacing it...
//content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif
Welcome to the forum and it looks like the Pilot will be sounding much better than the OEM Honda gear soon!
I don't know that I would have gone with the MTX prefab box over a custom built one but if that's what you wanted and it makes you happy then that, at the end of the day, is what matters most.
We will, of course, be expecting many pictures of the install process and full reviews of the gear once you've had a chance to tweak it all //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gifWelcome to the forum and it looks like the Pilot will be sounding much better than the OEM Honda gear soon!
Thanks for the good words //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif The only reason I went with a prefab box is because it was marked down to $9!!! It is made by Q-Logic and it perfect volume for the sub. I actually might try to sqeeze the sub into the stock location in the Pilot. There is a very weak 10" stock sub in this vehicle. If that doesn't work I know that I have a prefab waiting on the shelf //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Eh, just use your box you bought today, and don't even bother with the stock. I bet it wouldn't sound half as good. Make sure you unhook the *stock* sub!
how the hell did you get a q logic box for 9 bucks?
I bought the Q Logic at Circuit City when I went to buy the sub. They actually have other Q Logic pre fabs on sale. I was tempted to purchase the box that holds two 10"s, but decided againest it in the end. They also have a couple boxes to hold 12" for $12 I think. I guess these boxes are old stock that they must get rid of. I just opened my box to check everything out and the box was still wrapped in the plastic. I guess my wife has taught me a thing or two about bargain shopping //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
6
Dammned that sounds good!! I usually dont eat out. But Hmm. Tempting
91
6K
Not using the bass knob but amp to the touch,barely warm after 30 minute ride Edit: not going full tilt for that long either.way too loud for that...
9
This afternoon when I got in my car it took a few seconds for my subs to start working. I figured it’s because I’m in Florida and it’s...
PILOT 04
PILOT 04
OHIO
PILOT 04
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
