After reading up on diyaudio.com on what amps to use for my 3-way dipole towers, I am absolutely clueless:crap: Im not sure whether pro audio amps vs high end home amps make a difference sonically, and if I'd prefer either over another.
I need to power a pair of Peerless HDS 1" tweeters, a pair of Seas Excel W18Es, and a pair of Dayton RS15 HFs
The Peerless has a 93dB (8ohm) efficiency
The Seas Excel has a 86.5dB (8ohm) efficiency
The Dayton RS15 has a 90dB (4ohm), so effectively 87dB efficiency
Since the tweeter is roughly +6dB over the seas+dayton, im going to need 4x the power for both the seas and dayton
Im going to be using a DCX2496 for crossover/equalization and maybe a DEQ2496 for RTA use and other equalization purposes, if that means anything. Im also not sure what cd player ill be using (ive got an old cd player from the mid 1990s, sony or yamaha something along those lines)
What combination of amplifiers would you use to power this setup? I have a maximum budget of $800 (although I'd like to spend closer to $600).
I had fancied the idea of using 6 300watt BASH plate amps ($630 shipped from partsexpress), but am wondering about their high frequency performance.
