What do you guys think? Box for an 18
mrfreshnklean
I was thinking about building a wall and I think Im going to try my luck..
What would you think about an 18HC with 1500 watts in 11cubes tuned to 33hz?
Would it blow up? Would placing my gain below my HU output voltage keep my wattage to 1100-1200 watts when its turned up all the way?
Also can ports be too big? I didnt get that far but the port will be at the top, the full 50" wide.
Amp will be a hifonics brutus.
It'll definitely hammer out some lows. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Just gotta watch for overexcursion.. As far as port dimensions go, don't exceed a 9:1 ratio(I'd suggest not exceeding a 7:1 ratio) Go with around 120sq" of port(like a 20 x 6 port)
Personally, I'd keep the box closer to 8net 90sq", tuned to 33hz.
Either way, you'll be quite impressed I'm sure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Why keep cramming your subs behind the seats when its inevitable that something like this is where you'll end up anyway. Most 12's with an EBP...
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
mrfreshnklean
mrfreshnklean
St. Louis, MO
drjjg
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
