What subs ?
As long as he keeps the gain at the right spot he should be fine. Let me try to find another amp that does 1000watts rms. :thumbsup
Since that subs is dual 2ohm it will run at a 1ohm load or at 4ohm, to me 1ohm is better. So try this amp!
http://www.sounddomain.com/sku/POWA3000DB
That will run it at 1100watts rms, just keep the gain down to the right setting.
Total with that sub and amp its 670bux shipping is free at sound domain. With this amp you need to wire it at 4ohm load.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
eddie23452
eddie23452
West Palm Beach, Florida
AudioGuy
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
