which is better?
probably subs seeing as most components always come in pairs which can only be wired from two channels (correct me if i'm wrong).
As with everything else, it depends. If you can find a quality two-channel amp that makes the power you need at the impedance you need then it is good. If a mono amp can do the same thing it is good. Most newer mono amps are class D and have a rather limited frequency range which eliminates them from use as a mid-high amp. They are also generally more powerful and much more efficient than a simularly priced two-channel amp and this suits them to sub duty. If you are looking for really high power, mono Class D is pretty much the only way to go. For a modestly powered system, a two-channel amp can drive subs just as well as mono.
Go to Crutchfield.com There you input the vehicle information and the site will suggest the correct speaker sizes. After that you can seek better...
  • Poll
Then again, there's a chat group out there that is nothing but pure BS, and people eat it up like candy. The stock is making people money though...
109
3K
I really like RF amps, especially the power series, I have a T1000.1bdcp. However, I've never been a fan of their subs. Go with the DD. Other sub...
12
serg18
Bubblhead
serg18
Norfolk, Va/ Covington, Ga
limitkid7
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
