Which of these subs for SQ?
cjjackson85
Banned
8,918
Idaho
I want a system that is 70% SQ and 30 % SPL. These will be in sealed boxes. I will run 1 Rockford Fosgate bD 1000.1 per sub. Locally I can get these 12's:
2 Diamond TDX Dual 4s - $750
2 Kicker L7 Dual 4's - $575
2 MTX 9500 Dual 4's - $900
OR
Is there a way to hook up 2 Adire Brahmas to my amps with a 2 ohm load to each? This would be my choice, but I don't know if it is possible to wire it this way. Thanks.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
Aw.... You're talking about good ol' Mich.
15
741
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
474
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
405
cjjackson85
Banned
cjjackson85
Idaho
B_Master_Flash
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
