which would you pick?
Depends on your space you have. If space wasnt a issue and you want SPL with if you do it right fiarly nice sq (believe it or not with comps) i would go for the comps but a bigger amp. But if you want a nice kick with not much space taken the Rs are the way to go. I would also consider another amp not bad just better out there for the price.
I would go with the type r's. I have 2 type r 12's sealed 1cubic feet with just 340 watts going to each with and they some awesome. The sq is incredible but they also can shake the ground. With that amp and a ported box u can get **** loud and sound very good doin it.
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Shallow mount subs like those recommended are a favorite of truck owners. Typically the space under the seat is wide but “shallow” from bottom of...
nike_soccer2
nike_soccer2
Pittsburgh PA
88k5blazer
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
