why do my subs sound better in the back...
why do my subs sound better in the back of the trunk, close to the tail lights, as opposed to them being pushed up close to the front by the rear seats? my subs fire into the tail lights. i was just looking for a logical reason why they do this.
I can't give you a scientific reaon but I will say that in my earlier systems I used to point my subs backward for best results. I think it all depends on the trunk of a particular vehicle and not so much the subs. I have no proof of this but it is what I've heard and thats what worked for me until I bought a "fold-down" back seat and mounted my PRS's facing forward.
Adam
does it have to do with the wavelengths too? cause I know if I sit closer to the steering wheel, it feels like there's dip in midbass and an increase in sub-bass.
i think your exactly right with the wavelengths! i know competitors will bounce the wave around to make sure the crest(or whatever the most powerful point on the wave is) hits the the microphone for max spl. so basically your hearing different parts of the wave. i hope some senoir audiomaster can confirm what i said or tell me im full of **** since im still learning as well. i heard this while reading about transmission line boxes on car audio and electronics website, i wish i could fint the link.
i'm no audiomaster, but you are correct. it all has to do with directing sound waves. that is why people say it is all in the install. a cheap sub could blow away a nicer sub if the box is designed correctly according to the vehicle.
I remember back when i was into home theater i read that for every wall a subwoofer "sees" it will gain up to 3 decibels...I used to fire my subwoofer into a corner and reflect it off the walls to make it louder...it works. I would assume this is the same thing that's happening in your trunk. I wonder if someone has ever built a custom box that has the subs pointed exactly to where the trunk lid, back, and side all meet.
not unless you wanna hang some drywall in your trunk. the metal frame doesnt reflect sound like your home but to some extent that still seems an interesting idea.
you could build a box for your trunk and just leave one end open (the side that is against the rear seats). Like a box inside a box. I bet that would be mad loud...would take a lot of time to build, but it would probably keep people from jacking your stuff from the trunk side. If you did it well enough you wouldn't get much sound at all going out the back...it would all go up front. Or i guess you could just sound deaden the crap out of everything.
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
Need to know your setup. Just curious, before you connected it, did you check your resistance for your subs?
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
380
slick rick
OG
slick rick
Violates Miranda
justsayk
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
