Will this amp power 2 L5's?
basketball346
I'm looking at getting a kicker kx600.1 amp. It says it will produce 600 watts rms x 1 at 2 ohms. The problem i hope u can help me with is that i want to buy 2 kicker L5's (12"). Now i want to run the amp at 2 ohms, so how would i wire the subs so that i get 300 to each? and should i buy 2 dual 2 ohm subs, or 2 dual 4 ohm subs.
thanx
basketball346
dual 2ohm
i'd get the kx1200.1 for 2 12" L5's dual 4ohm run them down to 1ohm and get the 600wrms+ each
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
There is still power in the radio. Internal amplifier in the radio. Even when turned off. The radio is connected to external power amplifier...
7
817
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
basketball346
basketball346
Nazareth Pennsylvania
tat2
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
