wiring problems
Celicasav
I currently have two new rockford fosgate punch 2's and a rocford fosgate power 451s amp to push it. What is the best way to wire the subs? I was told my amp isnt two ohm stable in bridged mode. So I could bridge th amp at 4 ohm or 8 ohms. WHat do you think.
4 ohms. (ten characters)
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
You guys have any favorite wiring terminals/connectors? I'm talking about butt splices and T-taps. Need to be small enough as to not be bulky when...
It says you can you use a three-way speaker, not a woofer or two-way speaker to hook up a 4 ohm load. Mid-ranges on the two-way speaker. That...
5
402
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
648
Celicasav
Celicasav
Oakland, CA
LoneRanger
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
