wiring Q
exodus5139
12
Cali
Why does this pic show 2 pos and neg for one sub. I know there are 2 prongs coming of of each pos and neg wire of the sub, so would wiring it this way be the same as just wiring one pos wire to the amp and 1 neg wire?
well the little red X doesnt show much, but what you are describing is a dual voice coil sub, each coil has its own positive and negative
You guys have any favorite wiring terminals/connectors? I'm talking about butt splices and T-taps. Need to be small enough as to not be bulky when...
It says you can you use a three-way speaker, not a woofer or two-way speaker to hook up a 4 ohm load. Mid-ranges on the two-way speaker. That...
5
402
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
647
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
exodus5139
exodus5139
Cali
Acidburn
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
