Wiring relays for an amp?
Afboy143
aka Bumpin Expo
385
Tampa, Fl
I saw a big chart on how to wire relays and stuff for like amps, neons, and various other stuff. It was animated but I cant find it anywhere? So can someone tell me how to wire a relay for amps or get me a link for that chart? thanks!
You guys have any favorite wiring terminals/connectors? I'm talking about butt splices and T-taps. Need to be small enough as to not be bulky when...
It says you can you use a three-way speaker, not a woofer or two-way speaker to hook up a 4 ohm load. Mid-ranges on the two-way speaker. That...
5
402
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
647
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
Afboy143
aka Bumpin Expo
Afboy143
Tampa, Fl
Acidburn
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
