wiring trouble?
hume42069
22
H-Town
ok, i got a 10" audiobahn w/ dual 4 ohm voice coils... i need SPECIFIC info on how to wire it... i know to loop the pos to pos neg to neg, but then i dont know which negative slot and which positive slot to run to my amp... as you can see, im very confused and ne info would be grrrreat... help me out yall.
so it wont matter if i put the neg in and po out on the same side of the woofer? cuz there are four in/out slots per side...2 per side are taken up by the pos to pos neg to neg connections...it doesnt matter which of the remaining slots i use? and how to i wire the amp to the individual subs? what type and size of amp would be best?
You guys have any favorite wiring terminals/connectors? I'm talking about butt splices and T-taps. Need to be small enough as to not be bulky when...
It says you can you use a three-way speaker, not a woofer or two-way speaker to hook up a 4 ohm load. Mid-ranges on the two-way speaker. That...
5
402
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
647
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
hume42069
hume42069
H-Town
hume42069
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
