wiring two subs help!!!
Celicasav
I currently have two new rockford fosgate punch 2's and a rocford fosgate power 451s amp to push it. What is the best way to wire the subs? I was told my amp isnt two ohm stable in bridged mode. So I could bridge th amp at 4 ohm or 8 ohms. WHat do you think. I also don't really know what an ohm is and what 4 or 8 or 2 and how it makes a difference. Could someone shed some light on this topic?
An ohm is a unit of measurement, which in this case is the impedance of a speaker. If all you're doing is playing with speakers, all it is is a way to calculate how much power you'll give to each speaker. There's two formulas you use (which can be combined, but I really don't feel like doing it right now) to calculate how many ohms there are, depending on how it's wired.
(R1 is the impedance of speaker 1, R2 is speaker 2... up until RX, which is the last speaker)
Series:
R1+R2+...RX=R total. This is where you have your speakers (or subs) wired one after another, plus to minus, plus to minus the whole way through.
Parallel:
(R1+R2+...RX)/(# of speakers) = R total. This is where you've got all the plus's connected together, and all the minus's connected together.
The reason those are important is because at certain loads (ohms), an amplifyer will put out a different amount of watts. If you've got a pair of subs that are 4 ohms, and your amp is stable at 2ohms, then you should wire them in parallel to represent a 2ohm load. Therefore you get a lower overall resistance, and will get more out of your speakers.
Or if you want some decent examples....
http://www.crutchfieldadvisor.com/S-igC9ReVpdTD/learningcenter/car/subwoofers_wiring.html
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
5K
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
Sell the dual 2 and get another dual 4.
Celicasav
Celicasav
Oakland, CA
xSomeguyx
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
