woofer in front door???
aliante
phila
According to the bose sound system (for a audi a4 convertible) they put tweeters near the outside mirrors, midrange speakers in the dashboard, midbase speakers where you normally have the backdoor speakers and 20cm(=7.87") woofers in the frontdoor. What do you think about this setup? You think it will sound good? If yes, I was thinking of putting aftermarket speakers at those spaces and also probably an extra woofer in the trunk. I like the idea of woofers pounding directly in the cabin as the car is a convertible.
Second Q. Did anyone try to make a 8-14 liter enclosure in the frontdoor? Would this be possible at all? I reckon this is how much you'd need for a 8" JL woofer.
Third Q. Can anyone recommend a good installer in the phila region?
Thanks
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
648
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
4K
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
7
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
4
aliante
aliante
phila
paikiah
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
