XXX Subs
  • 3
crx11
ny
For the people that are running the XXX Subs from Resonant Engineering.
Do you like this subs?
What type of box sealed or Ported?
What numbers are doing with this subs?
What are you using for amp?
How do you wire then?
What Subs you was running before this one?
What sub you like better?
I need opinions from people that use or are using this subs now.
Thanks guys.
Originally posted by crx11 For the people that are running the XXX Subs from Resonant Engineering.
I did a full review of the woofer for Momentum Magazine
yes I did
both
Sealed
SPL @ Peak 129.2db @ 45 Hz
SPL @ 60 Hz 128.1db
SPL @ 40 Hz 129.0db
SPL @ 20 Hz 127.7db
Ported
SPL @ Peak 134.6db @ 45 Hz
SPL @ 60 Hz 1314db
SPL @ 40 Hz 131.9db
SPL @ 20 Hz DNA
I used 2 Cadence Z9000's (800 watts + per amp)
seried 2 coils onto each amp, 2.4 ohm mono per amp
the only relevant woofer before was the Adire Brahma 12"
they are both nice woofers.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Loyd L.
When your battery runs low while playing music, the radio will make odd sounds. Charge the battery and when installed, play the music with the...
64
I installed 2 12s and an amp in my 1998 ford ranger, everything is soldered and hooked up, tested power and ground they are good and the amp turns...
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
crx11
crx11
ny
crx11
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
