Zapco 500M Power
wesleywahl
I have ordered a Zapco 500M amp and 2 10" MB Quart PWE 254 subs. The amp is rated at 500w RMS @ 2 Ohm and 800w MAX @ 2 Ohm. The subs are rated at 400w RMS and are DVC 4 Ohm. I had intended on wiring these to 2 Ohm, but because I am kinda new to this stuff I didn't realize that you can't. Would this amp still provide enough power for these subs at 4 Ohms? I looked for specs for this amp at 4 Ohms but could only find for 2 Ohms. If not, would it be better for me to sell this amp and buy a different one, or would it be a good idea to buy another one of these and run one sub on one amp. I was afraid that this might be too much power then. If I should buy a different amp: I would like to sell this one if anyone is interested; and which amp should I buy. I think I would like to stay with Zapco but Im not sure which model would work best.
I would say try it...worst case sell the zapco and get a moer powerful amp. My old zapco 200 was the cleanest amp I have ever owned. you will still probably get around 350-400 watts at 4ohms. What does your birth sheet rate your 500m at?
Well, at four ohm, that amp will provide enough power to move the subs, but it won't take full advantage of the subs. That being said, Zapco is a truly premium brand and you're lucky to have that amp, I just wonder whether it might not be better suited elsewhere.
I take it that amp is a class a/b? If it is, you might want to consider using it to run your front soundstage. It would be a beast for that.
Not to say that it couldn't run the subs. Give it a shot and see how you like it. Zaps are truly amazing amps. I don't think I could part with one if I ever had the chance to buy one.
So I take it the problem is that in parallel, those subs produce a 1 ohm load, and the amp isn't built for it? Perhaps you should consider something like a Directed 600D?
Good luck
500m is a single channel and not 1 ohm stable, I have one hooked up to 2 kicker comp 15s and it works really well. They handle 250 each and I was pushing them really hard. The 500m is 2 ohm stable , I also tryed it on 2 kicker comp cvr 12s and that sounded great to. I switched to my older earthquake pa 2300 amp 600watts and it was a lot more power than the zapco. The bigger earthquake was the winner with the cvr 12s . The 500M will push the 10s no problem, 2 of the zapcos may be 2 much for the 10s . If you want to sell the zapco let me know.
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
I follow a guy on YouTube called PS sound he's a high-end car stereo installer in the UK yeah I'm talking like super high-end cars and expensive...
10
3K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
wesleywahl
wesleywahl
Nac, Texas
bondovw
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
