Zapco 500M Power
wesleywahl
I have ordered a Zapco 500M amp and 2 10" MB Quart PWE 254 subs. The amp is rated at 500w RMS @ 2 Ohm and 800w MAX @ 2 Ohm. The subs are rated at 400w RMS and are DVC 4 Ohm. I had intended on wiring these to 2 Ohm, but because I am kinda new to this stuff I didn't realize that you can't. Would this amp still provide enough power for these subs at 4 Ohms? I looked for specs for this amp at 4 Ohms but could only find for 2 Ohms. If not, would it be better for me to sell this amp and buy a different one, or would it be a good idea to buy another one of these and run one sub on one amp. I was afraid that this might be too much power then. If I should buy a different amp: I would like to sell this one if anyone is interested; and which amp should I buy. I think I would like to stay with Zapco but Im not sure which model would work best.
Zapco 500m=360 watts at 4 ohm. If you wanted to stick with zapco you could probably get another 500m or get a reference 750 which puts out 750 watts at 4 ohms bridged. Otherwise you could probably get into a cheaper one or four ohm stable amp that would work just fine.
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
I follow a guy on YouTube called PS sound he's a high-end car stereo installer in the UK yeah I'm talking like super high-end cars and expensive...
10
3K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
3K
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
wesleywahl
wesleywahl
Nac, Texas
Shugarra
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
