Issues with members Private Messaging
Buck
little alien on campus
I've had several people tell me they can't figure out how to private message or that it just isn't working. I mean it's probably a couple of people a week. Is there any issue with PM'ing or do you have to reach a certain forum status to PM? I'm just curious because it seems like a lot of people have issues private messaging.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
570
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Buck
Buck
Inside of a pyramid
Buck
    May 24, 2024
    May 23, 2024
