Question about amp. Digital Audio
1995mirage
USA
I have a Digital Audio DAB6754. I bought it new many years ago. It still works but I don't have any info on it anymore and can't seem to find any info online. Can anyone help with specs on this old amp? Thanks a lot!
By the model number you can assume it does 75x4 Watts. Does it have a 60A or 30A fuse? Multiply the fuse Amperage by 10, that will give you the best guess of it's power output.
Thanks for the reply. It's a 6 channel with 2 40A fuses. I was also thinking probably 4x75 for channels 1-4. I guess they were not very popular amps. I can't believe I can't find anything online.
That's all I could find on that amp
Digital Audio was basically another brand name they slapped on Audiobahn and sold through M&M wholesale catalog to pawn shops and suchlike. I'd imagine it is the same exact internals of an Audiobahn amp of the same era.
I'd take any ratings with a grain of salt and wouldn't attempt to push your luck running at low impedance or anything.
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something in my daughter's car for her. I have a 10" Kicker CompR with a Kicker CXA400.1. I think I'll use the Digital Audio for Memphis Audio PRX602 6.5" in the front and 5.4" in the rear
681
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
1995mirage
1995mirage
USA
1995mirage
