Binding post
So had a question about these I know how to put the wire through from the amp on (purple side) you just unscrew drop the wire in the hole and screw tight but my question was how do you connect the wire on the rear from the subs (blue) could I just solder it on there?
Yes. Ring terminals will work great. crimp them pretty good. You can hit with solder to make a secure solid connection, and then Heat shrink over the crimped area. Make a nice clean look as well.
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
Yes, Winky was triggered and butt hurt enough to start **** when I wasn't even talking to him.
Looking for an inexpensive double din head unit that has the following: Front/Rear/Sub outputs XM Ready Just want some ideas
Charlotte
