2013 Lexus RX350
  • 1
BCotrell
227
irvine, ca
Hey guys. Wife is getting new ride so I’m getting her 2013 Lexus RX350. Non navigation stock system with pioneer factory amp. Couple of questions.
1. Aftermarket amp with dsp built in or separate factory integration module like this
2. The front door is three way so there’s a pillar tweeter a small 1.5 mid and a lower woofer. Should i keep three way and wire the front and rear door midbass drivers together, keep the front three way and ditch the rears, or go two way on the front doors and keep the rears part of the system on separate channels
Thanks
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
12
BCotrell
BCotrell
irvine, ca
BCotrell
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
