6 channe amp
  • 5
Looking for a 6 channel amp for SQ setup in a Tahoe. Need 100 watts RMS or close per channel.
I have a SQ 5 ch amp 75x5 tube amp ..I was gonna run it active and use 5th ch for rear fill though they designed it for center ch..I also have a nice 6ch original Memphis Belle made like the early Soundstream amps rated 75x4 plus 150x2 ..I may have some others in my collection as well
I have a SQ 75x5 tube amp... I also have a nice 6ch original Memphis Belle made like the early Soundstream amps... I may have some others in my collection as well
You muthafukka. You got evthang. That Memphis Belle is nice.
208
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
411
6
493
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
785
soldiermedic
Noob4Life
soldiermedic
San Antonio, Texas
soldiermedic
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
