Kicker cvt 10 to port or not?
  • 4
jeramy88
So I am building a sub enclosure for my 05 f150 supercrew cab, it is .88 cubic feet down fire single 10" cvt 2 ohm sub powered by zx400.1 at 2 ohms and I'm debating on making it a sealed with poly fil or ported with poly fil or no poly fil. I'm going for sq and SPL too, just a nice low but clean bass.
Kicker recommends .8 to 3.0 cubic feet for sealed and 1.25 to 1.75 cubic feet ported and I have .88 cubic feet should I listen to these recommendations or will ported make this sub sound great?
Also not sure of hz I would need to tune it too?
All help is greatly appreciated!!
if you are not dead set on that sub, there are a lot of 8's that would shine in a ported box that size, and can be tuned pretty low. sundown audio, digital designs, cadence, skar, just to name a few.
---------- Post added at 10:42 AM ---------- Previous post was at 10:42 AM ----------
tuned as low as 30-32hrtz.
sealed boxes can be ok, i used to use them. then i got my first ported box, a 12inch rf t212 @ 33hrtz...never doing sealed again. some guys on here will rag on the kicker subs, but they are ok, especially if you already have it. some of the subs i mentioned are less than $150, but anyway, if you are restricted on space you can only work with what you have. as far as poly-fill, i can't speak on that, don't know enough about it. i think it has something to do with the sub "thinking" it is in a larger enclosure, something about slowing down the sound waves and whatnot.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
917
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
jeramy88
jeramy88
United States
THATpurpleKUSH
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
