Sub cuts out randomly, and always when I brake or Accelerate to fast.
Maybe a bad ground point. A week ago another user had the same issue (sans radio issue). It was a bad ground.
When I checked my connections I had power going through the ground. I had ground off the paint so its clean metal to metal.
I think its just the amp. It is a cheap Walmart amp, it was only 60$. I'll just go buy a quality one for more money.
Check your grounds! Both head unit and amp. I had this issue before and it was a grounding issue. Ground wire made enough contact to play low...
246
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
563
Jackson D
CarAudio.com Newbie
Jackson D
Idaho
Jimi77
Decebal
    Jun 10, 2024
